92 Camaro RS Belt Tensioner help!
Car: 1992 Camaro RS
Engine: V8
Transmission: Automatic OD
Hi, I have a 1992 Camaro RS (V8 5.0L 305 engine automatic) that had the entire drive belt tensioner assembly "pop" off while driving up a steep incline. Lost power steering, cooling, AC, etc. Had to have my car towed 25 mi home. The tow truck driver opened the hood, handed the entire assembly (figure '8' shaped part with a huge spring inside one side + whitish pvc-esque inner washer, pully wheel on the other side) and the belt (which is only 2 months old-good condition). The bolt still attached to engine (as far as I can see).
Here's my question(s) are: How do you know if the assembly is old and must be replaced? Is this easily repairable (i.e. I can put the one that came off back on if I just remove the bolt or replace a pulley, etc?) or do I need to buy an entire new assembly ($65.00 +labor)?
(I've attached a pic of the assembly, minus the white pvc part and bolt)
Thank you for your help!
Car: 87 IROC Z-28
Engine: 5.0L 305 TPI V8
Re: 92 Camaro RS Belt Tensioner help!
Car: 1990 Formula Firebird
Engine: 350 (5.7) TPI
Transmission: WC T5
Axle/Gears: 3.42 POSI
I just bought one off Rock auto myself. It is very easy to install, no need for a shop.
Car: 1990 Camaro RS
Engine: 305 L03
Transmission: 700R-4
Axle/Gears: 2.73 Posi
Bro if you're on these forums you can install it yourself. It is like one bolt. Buy a new one or a good used one. I would not reuse something that inexpensive that already left you stranded once. It is a torx head bolt so if you don't have that kind of socket you'll need to pick up a set. There are several bolts on our cars that are torx so it would be a good idea to buy a set anyway.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
1992 Trans Am
May 10, 2023 07:19 PM
Navy8125
Aug 22, 2015 07:13 PM
TRANSAM82-92
Interior Parts Wanted
Aug 15, 2015 01:26 PM
db057
Aug 11, 2015 10:11 PM
