Mechanical Pump to Carb Fuel Line Replacement
Old Jul 22, 2012 | 01:07 PM
JLCustomizing's Avatar
Car: 1984 Trans Am
Engine: 5.7 Liter V8
Transmission: Auto 700R4
Axle/Gears: Stock
I have a 72 camaro 350 block with the 84 firebird heads, upper intake, and quadrajet. I have a mechanical fuel pump and need to change my metal fuel line from the pump to the carb and was trying to figure out which one to use, the 72 camaro line or try to find an 84 firebird line. Any ideas?
It was looking like my easiest route is to just use a stainless steel braided line and put the quadrajet fitting on it. Anyone know what fitting I would need for the fuel pump side?
Old Jul 22, 2012 | 02:43 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: Mechanical Pump to Carb Fuel Line Replacement
There isn't a good one. Aeromotive says they sell an adapter for those flange type fittings, but the one I got to try (going from my actual fuel line to regulator), didn't fit at all. 3/8 fuel line and I got the 3/8 adapter...the adapter is to large as far as I can tell.
Now, I have seen the factory steel line set up that goes from the mechanical pump to the carb for sale online. Can't remember where though, but I do know they can be had. I'd start with Classic Industries and go from there.
Old Jul 22, 2012 | 04:39 PM
Car: 1984 Trans Am
Axle/Gears: Stock
they say they have one for an 84-86 305 4bll camaro/z28. This should work fine I'm guessing since I have an 84 firebird originally a 305?
http://inlinetube.com/Preformed%20Li.../CC-CAT-08.htm
Old Jul 22, 2012 | 04:45 PM
Ozz1967's Avatar
Car: 1984 Trans Am
the 8601? Yeah, that should be it. There would have been no difference between them.
Frozer!!!
Jan 19, 2024 04:55 PM
specialized
Jun 18, 2022 09:26 AM
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
AkDrifted
Aug 17, 2015 07:45 PM
