Distributor
Old Jul 27, 2012 | 11:37 PM
rockportbird's Avatar
Car: 1991 Firebird convertible
Distributor
Removed distributor on my '91 Firebird 5.0 TBI to replace pick up coil. Me & 2 buddies have spent over 10 hours trying to get dist back in. Won't drop that last 1/4" onto oil pump shaft. Never had so much trouble installing a dist before. Any hints?
Old Jul 28, 2012 | 04:15 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Re: Distributor
Assume you know to index the pump drive shaft, so that it's slot lines up with the tang on the dist?
If that's not it, I had a different issue once. Is the car on a slope? I had to change the dist with the car in the street parked on a downhill slope, rather than on the flat in the garage. It was enough to tilt the pump shaft forward just a little, and make engagement nearly impossible. That took me a couple of hours before I twigged to it.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
Damon
Sep 26, 2015 04:29 PM
