89 2.8 camaro HEEELP (vacuum lines)
Old Jul 28, 2012 | 07:02 PM
eddo520's Avatar
Car: 89 camaro
Engine: 2.8
Transmission: 5 speed
Does any 1 have a 2.8 litre camaro??I need a huge favor pictures of where these damn vacuum lines connect to someone hellp im gooing crazy
Old Jul 28, 2012 | 07:20 PM
project89's Avatar
Re: 89 2.8 camaro HEEELP (vacuum lines)
which lines do u need to know were they go.
the 2.8 has a very simple vacum system on it
Old Jul 28, 2012 | 07:29 PM
eddo520's Avatar
Car: 89 camaro
Engine: 2.8
I need the 2 that come out rite above the throttle body and the 1 coming out the top of canister in front of car and the tiny canister by the alternator ,I just don't understand the diagram
Old Jul 28, 2012 | 08:11 PM
project89's Avatar
right above the throttle body one of them goes to the fuel presure regulator
and the other goes to the egr soiliniod
the one on the canister is the charcoal canister u might need to take a picture cause if i recall corecttly there are 2 vacum lines on that
the canister by the altanator is more then likley ur heater control valve, there should be a line comming out of the firewall near the heaterbox between the heaterbox and the engine that connects to that
does the canister by the alt have 4 hoses running to it ? if so then its deffinatly the heater control valve, if not its something else but i dont recall the 2.8 ever having anything else that took a vacum hose by the alt
Old Jul 28, 2012 | 11:59 PM
eddo520's Avatar
Car: 89 camaro
Engine: 2.8
Yeah the charcoal box has bout 4 vac lines 1 or 2 ain't connected the 1 by the alternator is just a single Ryt behind the alternator . Ill post pics in the A.M,this Camaro does not have cruise
Old Jul 29, 2012 | 02:05 AM
camarosrock1989's Avatar
Car: 1989 Camaro RS--
Engine: MPFI
Hey eddo what part of Az? if 520 is you code i am in the same area. Message me and if we are close i will just meet you and you can look under the hood.
Old Jul 29, 2012 | 10:53 AM
eddo520's Avatar
Car: 89 camaro
Engine: 2.8
I sent u my # in ur box. Thx!
Infested
May 22, 2018 11:56 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
theshackle
Mar 5, 2017 06:37 PM
cstrobel65
Aug 15, 2015 10:19 AM
apie2546
Aug 10, 2015 05:43 PM
