Freeze plug leak
Old Aug 1, 2012 | 11:48 PM
Big Matt's Avatar
Car: 1984 Camaro
Engine: L69 305 HO
Transmission: T5 Borg Warner
Axle/Gears: Auburn LSD / 3.73
Freeze plug leak
Well I had a leak in one of the freeze plugs on the back of the engine so I dropped the transmission and pulled out the freeze plug. I found a good size notch in the block where the plug seals (picture below). I got a new freeze plug and put some Permatex RTV but I'm not sure if this will work. Are there any other options to fixing this? Also would I need to put the transmission back in to start the engine to see if it leaks, or will the engine run fine without the transmission in?
Attached Thumbnails Freeze plug leak-2012-08-01_21-02
Old Aug 2, 2012 | 07:08 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: Freeze plug leak
There is a rubber freeze plug replacement that might work here. You would push it in the hole and then when you tighten a nut in the center it pulls a metal plate that expands the rubber. You should be able to find them at your local parts store.
Old Aug 2, 2012 | 09:14 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Don't need to start the engine to pressure test it.
Infested
May 22, 2018 11:56 PM
LittleFranks
Sep 17, 2015 12:22 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
cstrobel65
Aug 15, 2015 10:19 AM
