vortec spring question
Old Aug 7, 2012 | 10:45 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
well on my build for now i went ahead and bought a 95 lt1 cam for my vortec build up, since the original cam is around the same size as the lt1 cam i just installed, can i resuse the stock valve springs now?
Stock cam specs were .414/428 lift and .191/.196 duration
95 lt1 cam specs are 205/207 duration and .447/.459 lift.
Old Aug 8, 2012 | 10:50 AM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
Re: vortec spring question
Nope, not unless you want to limit your rpm to about 5000.
I'd get this kit: http://www.alexsparts.com/valve-spri...rf-hyd-roller/
Old Aug 8, 2012 | 10:54 AM
Engine: L31 350
Those are what I'm looking at. Okay thank you
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
