firebird steering reassembly
Old Aug 10, 2012 | 08:03 PM
Col1989's Avatar
Hi, I recently purchased an '89 Firebird and the first thing on my list to take care of was the loose tilt steering. I tightened the four bolts that cause the problem and I am in the process of reassembling everything. The problem I am now having is the ignition switch rack preload came off and I am not sure where it belongs. Can anyone explain to me where it goes so i can finish this up. Thanks.
BTW, for reference the part I am talking about can be found here:
https://www.thirdgen.org/forums/tech...mn-repair.html
in the diagram posted by ASE doc numbered 36
Old Aug 10, 2012 | 09:43 PM
Col1989's Avatar
Re: firebird steering reassembly
well guys, as it turns out my brother found some detailed shots of the tilt steering assembly online and we were able to re assemble everything. Thanks to the original posters of the diy tilt steering fix as it was a great help. it can be found here:
https://www.thirdgen.org/forums/susp...-steering.html
In case someone has the same problem here is a link to the pictures we used:
http://www.diyfiero.com/dropspot/Jaz...ck_Rebuild.pdf
1992 Trans Am
May 10, 2023 07:19 PM
Squeaky8791
Feb 5, 2020 08:29 PM
colton_carlson
Mar 8, 2019 12:21 PM
deracer
Apr 11, 2016 12:04 AM
wild1
Aug 27, 2015 09:01 AM
