Initial start up no oil pressure help
Old Aug 14, 2012 | 04:14 AM
walkereod's Avatar
Car: 85 Camaro Z28
Engine: 305 LG4 4 bbl
Axle/Gears: Stock
I freshened up an 86 305 with new gaqskets and seals and oil pump to put in my 85 Z28 (Same engine codes). It is the LG4 4bbl engine. I did my intial start up last night and it sounded great and had a bit over 30 psi oil pressure. After running it for a couple minutes the oil pressure dropped to zero and the engine started to sound like poop. I shut it down and it still rotates. What do I do now?
Old Aug 14, 2012 | 08:33 PM
FtrSpeedy's Avatar
Car: 14 scion tc/91 camaro rs
Engine: 2.5/ 360 pooch
Transmission: 6spd man/th350
Axle/Gears: na/2.73
Re: Initial start up no oil pressure help
Pull oil pan recheck oil pump.
Old Aug 14, 2012 | 08:47 PM
zraffz's Avatar
Car: 1987 Camaro
Engine: LQ9
Axle/Gears: 4.10
How is the pickup tube/screen/filter held onto the pump?
Old Aug 15, 2012 | 12:46 AM
waltersb's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 305 TPI (LB9)
Transmission: Auto 4
Maybe it blew a gasket... I had an issue with an oil change recently where the rubber gasket didn't come off the housing and I didn't notice... replaced, 2 gaskets, oil everywhere. Is your oil level fine?
89GTAOz
May 16, 2020 09:31 AM
db057
Aug 22, 2015 08:17 PM
Navy8125
Aug 21, 2015 09:32 AM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
