Is there a seal between master cylinder and brake booster?
Old Aug 20, 2012 | 07:21 PM
Jfinnkma91's Avatar
Car: 1984 Chevy Camaro
Axle/Gears: 7.5in 10 bolt with 3.08
If there is can it be replaced or do I gotta replace the whole master cylinder?
Old Aug 20, 2012 | 07:38 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: Is there a seal between master cylinder and brake booster?
The booster is sealed and shouldn't leak air.
The master is sealed and shouldn't leak fluid.
If either is leaking, replace it.
Old Aug 21, 2012 | 07:59 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Yes, there is a rubber seal that sits in the recess of the booster. Round and flat with a hole through the center for the pushrod. Typically supplied with a booster, maybe found on a Help rack?
RBob.
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
redmaroz
Aug 16, 2015 11:40 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
