MSD 6AL???WORTH BUYING?
Car: 1984 Z28
Engine: 5.0 L (Carbed)
Transmission: 5-Speed
Axle/Gears: Lazy 2 check
So I got a 84 z28 5-speed, and I was wondering if one of these MSD 6AL's are actually worth it?Would I notice the difference? and how exactly do I install them ,is it difficult
?To my knowledge I have a factory stock distributor. thank for the help
?To my knowledge I have a factory stock distributor. thank for the help Member
Car: 1982 Z28 & 1967 RS & 2002 Z28
Engine: 388 ci SB / 454 ci BB / LS1
Transmission: 4 speed / TH350 / T56
Axle/Gears: '91 "1LE" rear, posi w/ 3.23's
Re: MSD 6AL???WORTH BUYING?
Do you have any other performance mods ?
As just a stand alone purchase, I think there are smarter items than a 6AL ...
~DaVe
~DaVe
Car: 1988 Gta
Engine: 383
Axle/Gears: Stock
Much debate here...Purportedly your car will run "better" because you will get a cleaner or more complete combustion because of the stronger spark. I just installed one on my GTA. Not hard to install. Do I notice a difference....yeah a little. If your car is basically stock...don't bother. If its modified a bit and money is no bigger what the hell go with the box. Locate it either in the car or a good spot I found is up near the canister on passenger side. To make it really easy to install purchase the plug n play harness that plugs into your coil and the MSD wiring. Piece of cake. I've never run an MSD before on any of my cars...now that I have one...eh.
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Unless youre running a bunch of compression with a massive cam nitrous or blower MSD boxes are 100% waste of money your car wont make another ounce of power.
HArd to beat a GM HEI
I hate having one cause I know one day it will strand me but would probably foul plugs eventually without it.
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Car: GTA
Car: 86 IROC
Engine: 350 Vortec TPI
Axle/Gears: BW 3.27
Pre 87 had the cap in coil. 88+ went to the External coil HEI dizzy.
Car: GTA
Sounds Bass-Ackwards. Pre-HEI had external coils. Everybody knows that.
So your gonna tell me that GM had external coils...Went to Internal coils...Then back to external coils? That in no way explains the 90 & 92 I had, both with internal coil dizzies.
Car: 86 IROC
Axle/Gears: BW 3.27
Believe it or not, They went from external to internal back to external. I think even the LT1's had an external coil.
If I am not mistaken 88 was the first year of the external Coil. 90-92 definitely had external(unless they were swapped out or converted to pre 87 MAF and did not want to cut up the harness)
To Add to the OP question. My brother added a 6AL as he had a carb car and needed a limiter. He added the ignition box and he said he noticed a difference. Started better, idled smoother and throttle response was better. As for more power, I doubt it made a difference, but drive ability was better. Plus if you can find one for a decent price on the boards and plan to stay with the sbc, why not.
Edit: HEI is both internal and external coil. It is the type of Ignition it is, not coil placement.
Engine: 383 Carb
Transmission: 4L60
Everybody knows that whether the coil is internal or external has nothing to do with whether it's HEI or not. HEI was GM's name for their points-less electronic ignition that came out in 1974 and was used on every engine in 1975. Ever distributor between then and the Optispark was HEI, regardless of whether it was large or small cap with an internal or external coil.
But regardless of that, the stock distributor for 1984 is large-cap, internal coil.
Car: GTA
As for "90-92 definitely had external"? I guess the stealership was in the habit of swapping stuff out in cars on their lots?
I'm done.....My personal experience has proven otherwise & I'm not playing this game anymore. Unsubscribing now, so bicker among yourselves.
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
I have a huge chunk of money into my motor, and outside of MSD 8.5mm wires, I left the ignition alone. MSD ignitions are a waste of money in my opinion (in most applications). They aren't BAD persay, but I can think of a lot better ways to throw my change. Got $35K into your motor? You'll probably like the few small additions they offer.
.. this thread got derailed
As mentioned above somewhere, one of the nicest features is the built in rev limiter ! OR you can even get a built in two step with the 6AL-2
Another option that I would consider is an upgraded module and coil for your stock HEI, both can be had CHEAP ! and would probably be the same benefit
~DaVe
~DaVe
Hotrodboba400
Dec 10, 2019 07:07 PM
BumpaD82
Feb 26, 2016 02:57 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
