belt tensioner
Old Aug 26, 2012 | 12:00 PM
maro3rdgen's Avatar
Car: 1989 camaro RS convertible
Engine: 305 TBI stock
Transmission: 700-r4
belt tensioner
how do i replace the belt tensioner pulley on my 89 camaro? i know its an easy job but i have never done it before and i dont want to screw anything up. thanks
Old Aug 26, 2012 | 12:10 PM
Jason C. Laney's Avatar
Car: '90 rs
Engine: 305 tbi for now
Axle/Gears: stock rear for now
Re: belt tensioner
a 3/8"drive ratchet should fit into the belt tensioner so you can release tension off belt. take belt off alternator pulley, no need to remove belt from engine. tensioner wheel is simply bolted onto tensioner. if memory serves, you might have to take tensioner assembly off engine, which is just one bolt. don't worry about reassembly as tensioner will only fit on one way.
Old Jan 14, 2014 | 10:35 AM
EvelBist's Avatar
Car: 89 Black GTA
Engine: 'close to' stock 5.7 but trending>>
Transmission: 700
Re: belt tensioner
small correction: use a 1/2" breaker bar in the square hole at the top of the tensioner arm, and rotate towards the passenger fender to release tension on the belt, remove the belt. Use a 13mm socket on the tensioner pulley bolt to remove the pulley.
I've found that the Autozone, and oreilly's replacements have bearings pressed too far into their bores resulting in the 13mm bolt actually locking the pulley against the arm - very bad for the belt. You have to press the bearing into the bore about a 1/4" further to get the depth correct.
But, a better, cheaper method is to press the old bearing out from the OEM pulley, and replace it with a NTN 203 type bearing (Grainger part number 1L016). They cost about $9 and let you reuse the OEM pulley.
Old Jan 14, 2014 | 11:18 PM
TallTim's Avatar
Car: 1989 Formula T-Top
Engine: 350 TPI, twin turbo
Re: belt tensioner
Evel can the bearing be swapped without a press? Thx.
Old Jan 15, 2014 | 06:52 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
Re: belt tensioner
You can get just a replacement pulley (with bearing) w/o having to replace the whole tensioner if its still good i.e. moves freely, doesnt bind up. I think the pulley is like $15-20, while the tensioner is $50.
Old Jan 24, 2014 | 06:00 PM
JunJun's Avatar
Car: 92 camaro convertible z28
Transmission: Swapped from 700R4 to T5
Axle/Gears: Stock Posi. Ratio is not known
Re: belt tensioner
What's the bolt torque when replacing the whole assembly?
sparks454
Interior Parts Wanted
Oct 18, 2015 03:18 PM
SRKLEGIN
Oct 12, 2015 07:28 AM
SRKLEGIN
Sep 30, 2015 07:19 PM
anesthes
Sep 30, 2015 07:48 AM
kitt23
Sep 26, 2015 07:48 PM
