rpms and starting problems
Old Sep 3, 2012 | 03:35 PM
necrobird's Avatar
ok so after i added MMO to the tank and that caused my O2 sensor to be fouled and run the GTA rich for a while, i replaced the O2 sensor that helped but has not solved the problem completely my the GTA still idles rather high it is mostly on 1000 rps rarely droping to 800 rpms when is completly motionless and since i run the car with MMO its harder to start, in the first crank as soon as i turn the key i hear what seems like a misfire and then in a second try the car starts right up what could cause these things its a 5.0 5 speed
Old Sep 3, 2012 | 03:48 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: rpms and starting problems
This probably doesn't have any thing to do with it but how do your plugs look?
Old Sep 3, 2012 | 04:24 PM
necrobird's Avatar
oh yeah i changed the plugs after having this problem
92camaroJoe
Jul 29, 2023 07:57 PM
perZ
Aug 15, 2015 01:17 PM
92camaroJoe
Aug 13, 2015 06:07 AM
hokis
Aug 9, 2015 03:57 PM
