TB coolant bypass done, but still warm
Old Sep 3, 2012 | 04:12 PM
thaemcee2's Avatar
Car: 1989 Trans Am GTA
Engine: L98 350
Hey guys I just did the throttle body coolant bypass and took the car out for a quick spin to see how much cooler the TB would be after running. the TB was def. cooler than before the bypass, but it was still pretty damn warm too. could it be because I just left the water inlet s on the TB open? should I run some hosing from them down to help "cool" a little better? thanks guys
Old Sep 3, 2012 | 05:11 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: TB coolant bypass done, but still warm
No, nothing else is required.
Heat is a relative term. After you drive your TPI and shut it down and let it sit for 10 minutes, heat soak will warm it up. But while driving it, it will stay relatively cool.
Old Sep 3, 2012 | 10:33 PM
PhoenixFirebird's Avatar
Car: 1989 Firebird Formula
Engine: 385
Transmission: Full Manual TH350
Axle/Gears: Moser 9" 3.70
You also have to remember, it's all metal. Eventually, all the heat from the motor is going to reach the TB. After driving for a while, feel the plenum and runners. They'll be hot. And all they have is air going through them! There's really no real way to keep the TB cool, the bypass just keeps 180-200 degree coolant from heating it up faster.
At any rate, it makes TB removal a LOT less messy
sheachopper
Jul 31, 2019 11:27 AM
mfp189
Sep 27, 2015 09:25 AM
