while I have the eng/trans out l-98 should I?
Old Sep 12, 2012 | 11:13 AM
Sammit87's Avatar
Car: 87 Iroc-Z/28, 96 Z71, 02 Suburban
Axle/Gears: 9-bolt 3.27
I have the engine trans out, I was wondering if anyone thats done this has any advice (woulda,coulda shoulda) seeing how everything in easy to get at right now. 1987 iroc l98 bone stock ... Sensors? injectors? BTW I ain't looking for mod-advice I'm leaving it original.
Old Sep 12, 2012 | 04:07 PM
91phoenix's Avatar
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
Re: while I have the eng/trans out l-98 should I?
Now is a great time to start cleaning and repainting the crossmember and the rest of the engine bay. Also be sure to check things like your rubber engine mounts.
Old Sep 12, 2012 | 04:26 PM
Sammit87's Avatar
Yeah good idea, you think I should change all the sensors and injectors too?
it did run good before the tear down though.
Old Sep 12, 2012 | 05:48 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Spray with gunk,scrub,rinse.spray,scrub,rinse,spray,scrub,rinse. Ah you get the idea.
Old Sep 12, 2012 | 06:26 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
This is a good time to reseal things. Any place where you see leaks, replace gaskets and seals. Take a good look at your underhood wiring. By now alot of the factory corregated loom has gotten brittle and broken off. Replace it now while it's all accessible Repair/replace any bare wires or broken connectors.
F.I. 57 Belair
Aug 23, 2021 01:09 AM
roysatikas
Sep 22, 2015 08:15 PM
Magman
Sep 13, 2015 08:43 AM
Magman
Sep 13, 2015 12:14 AM
