I need a quick response here
Old Sep 15, 2012 | 06:53 AM
Lo3 maniac's Avatar
Car: 1990 camaro rs
Engine: 5.0 305
Axle/Gears: Limited slip 2.77 gears
Im replacing my air cleaner in my 1990 rs 305 tbi 700r4 and I need to know what to do with the sensors. All of the, including the one on the snorkel. I am replacing it with an edelbrock 14 inch chrome cleaner
Old Sep 15, 2012 | 07:20 AM
Justin89Formy's Avatar
Car: 89 formula 350
Engine: ls1 magnuson tvs2300 supercharger
Axle/Gears: 4.11 Dana 44!
Re: I need a quick response here
I assume you mean the idle air temp sensor? I would add a grommet to the new air cleaner and keep it, but maybe put it in the back, out of view. It really is a helpful little sensor
Old Sep 15, 2012 | 07:38 AM
Lo3 maniac's Avatar
Car: 1990 camaro rs
Engine: 5.0 305
Yeah there's two inside the old cleaner one attached to the passengers side one down. By the tb and one on the snorkel I need too know what todo with all of them
Old Sep 15, 2012 | 07:53 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
the one with the vacuum hoses going to it is for the heat stove.. just remove it and plug the port on the carb.. the iat (inlet air temperature) sensor can be installed in the new air cleaner wherever it clears.. one thing you forgot is that you will need to either get a breather to replace the breather tube that goes from the passenger side valve cover or plumb that into the base of the air cleaner somehow.
Old Sep 15, 2012 | 08:25 AM
Lo3 maniac's Avatar
Car: 1990 camaro rs
Engine: 5.0 305
So can I just buy a little breather filter? Like the ones autozone sells?
F-body-fan
Jan 12, 2023 01:49 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
3.8TransAM
Sep 27, 2015 08:37 PM
