91 trans am wont accel after intake reseal
Old Sep 15, 2012 | 06:06 PM
jerm5801's Avatar
Little background on the car. I just bought it a few months ago and the intake and water pump were leaking. So last month I decided to reseal the intake and repalce the water pump. I also put in new plugs, wires, cap, rotor and coil. Well after a month of blowing it off i finally put it all back together today. Start it up to bleed the air from the cooling system and my ses light comes on.
code 23 for the iat sensor.
I decided to go give it a drive around the block and find out it wont move when i hit the gas. Would a iat sensor cause this? I figure if the sensor is bad and showing 5v it should just make it run rich, but it should still move around at least right? I had the car running for a good 15 minutes, and it seemed to run fine. I didnt notice any misfire while idling.
Just wondering if anyone else has any ideas on this? I was hoping to enjoy a nice cruise tonight with the weather being so nice
--fixed the dtc 23. I left the sensor unplugged under the upper plenum. oops. plugged it back in and tried to drive it. i can get the car to move under light to part throttle but any heavy throttle and it bogs down real bad
Old Sep 16, 2012 | 01:05 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
Re: 91 trans am wont accel after intake reseal
the iat is a controlled vacuum leak that the ecm uses to maintain a steady idle speed.. sometimes they get gummed up and don't seal, which causes a vacuum leak, which causes the engine to run really lean, which causes it to die..
pull it out and clean it up with some carb cleaner..
i don't know if there is any kind of adjustment to it on your car or if the ecm automatically does it, but i do know that there is a procedure to adjust the one on my 84 Regal T Type...
Old Sep 16, 2012 | 10:05 AM
jerm5801's Avatar
When I had the intake apart i cleaned everything in the throttle body. It seems more like its running rich. I can smell fuel, and i have almost no throttle respones unless its light throttle.
Could timing cause this?
Old Sep 16, 2012 | 10:42 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Sounds like your timing is off.
Also check your fuel PSI regulator vac line for raw fuel.
Old Sep 16, 2012 | 11:42 AM
mjdavis68's Avatar
Car: 88 IROC Z/28-under re-construction
Engine: 5.7 Tuned Port
Transmission: It's in there....
Axle/Gears: 9 bolt Borg-Warner
+1
Old Sep 19, 2012 | 07:18 PM
jerm5801's Avatar
timing was def. the issue. was advanced all the way off the indicator. the line was showing up at about the 3 oclock position. oops.
runs great now though!
1992 Trans Am
May 10, 2023 07:19 PM
tazs2000
Jul 15, 2017 08:44 AM
PestilenceIV
Aug 20, 2015 02:33 AM
marcusaw
Aug 10, 2015 08:13 AM
