removing useless parts
Old Sep 15, 2012 | 08:25 PM
mballejos87's Avatar
Car: 1984 camaro
Engine: 305 v8
Transmission: auto 4 speed
i have an 84 camaro sport coupe 305 v8 i want to know what parts in the engine bay i can take off that i dont need like the smog pump
Old Sep 16, 2012 | 01:10 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
Re: removing useless parts
what you "need" depends on whether or not you have emissions testing, and whether they do just a tailpipe test or if they do a visual to make sure everything is there..
i'll just assume you have no testing like here in MN..
you can take everything off the front of the motor except the alternator, PS pump, and AC compressor if you have AC.. you can throw away every vacuum hose except for the one for the pcv valve, the one that goes to the AC unit, and the one to the power brake booster.. you can get rid of every wire except for the alternator, distributor power plug, and AC clutch..
however
if you get rid of all of that stuff, you will have to get a carb and distributor off a late 70's car or truck with a small block.. you would need the distributor that has mechanical and vacuum advance built into it and a carb that doesn't have an electrical plug on it..
getting rid of all that useless crap really opens things up under the hood- you can actually see the engine- and makes it a lot easier to work on things.
Old Sep 16, 2012 | 01:47 AM
ibmtech's Avatar
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
And if you sticker under the hood says it was EFI, and you are not running EFI, and your state wants to be a bunch of a$$hole$ it can fail inspection..
Old Sep 16, 2012 | 02:03 AM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
If you don't need to pass smog then just take off everything that isn't necessary...
Old Sep 16, 2012 | 06:55 AM
ibmtech's Avatar
Car: 1987 IROC-Z
Old Sep 16, 2012 | 01:11 PM
Car: 1984 camaro
Engine: 305 v8
thanks i live in a small farm town in az so i dont need to do anything emmissions related i had to get a new carb a year ago to get it running so i got an edelbrock my catyltic coverter clogged to i gutted it then yesterday i took off the smog pump
Old Sep 16, 2012 | 04:57 PM
novaderrik's Avatar
Car: 86 Camaro
some states don't have any kind of inspection or emissions testing.. i'm lucky enough to live in one of them.
and stickers are easy to take off...
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
1nastygta
Aug 8, 2015 07:38 PM
3rdgenparts
Aug 8, 2015 07:09 PM
