1991 305 TPI -> valve seals (HELP PLEEAASE)
Old Sep 17, 2012 | 12:11 PM
Dennis-Z28's Avatar
Car: 1991 Z28 Convertible
Transmission: 5-speed
Axle/Gears: 10 bolt, 3.08
In the process of putting in new valve seals on my 1991 TPI Camaro.
Took the springs off of one cylinder. Neither had the O-ring at the top (assume broke up and flushed away). The intake had its lower seal with the two gold colored reinforcement rings around it. Exhause had nothing. I was expecting to see a hat style seal.
Does the exhaust normally have this or what?? I want to know before moving onto the next cylinder. Any help would be great, thanks. {hopefully someone knows}
Old Sep 17, 2012 | 11:21 PM
Dennis-Z28's Avatar
Re: 1991 305 TPI -> valve seals (HELP PLEEAASE)
Well, did all 4 cylinders on the driver side and none had hats on the exhaust. I added them so hopefully that does not F it up. only 3 of the 8 valves had any 0-ring left on them. so anything should help.
gta90
Sep 15, 2015 04:00 PM
NBrehm
Aug 25, 2015 11:49 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
