Lots of pressure in fuel tank
Old Sep 19, 2012 | 10:14 AM
blackbeauty89's Avatar
Car: 1989 Pontiac GTA/2007 TrailblazerSS
Engine: 350 L98/LS2
Transmission: 700-R4/4L70E
Axle/Gears: 3.27/4.10
Everytime when I go to put gas in my car there always seems to be a huge amount of pressure release once I crack open the gas cap.
Also after driving, I hear the fuel tank pop after it sits a few minutes. All of this normal?
Old Sep 19, 2012 | 12:48 PM
albertgeorge1's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Re: Lots of pressure in fuel tank
My 92rs releases pressure too but cant say ive heard the fuel cap pop. Maybe change the cap
Old Sep 19, 2012 | 01:05 PM
fervernt's Avatar
Car: 91 firebird Formula 350
Transmission: N/A, working on a t5 swap
Axle/Gears: 3.73 posi
Not the cap, the whole tank. The metal is flexing from the pressure. Some pressure is good. That much is usually not so good. I've heard stories of tanks cracking from too much pressure. Check your charcoal canister and solenoid 1st, they are responsible for venting excessive gasses and pressure from the tank. I've never checked it myself but the solenoid failing is common. Search for how to check it. Ill see if I can find a link as well. Also try and pick up a vented gas cap. I've heard mixed review about how effective they are though, so just try it out and see
Old Sep 19, 2012 | 01:12 PM
Car: 92 Camaro RS
Engine: 305 TBI
O yea my bad the tank flexing is bad! Again tho that could be ur cap i had a honda that did that i replaced the cap and all was good just a idea tho
Old Sep 19, 2012 | 01:20 PM
akanitro's Avatar
Car: 1989 GTA, 2004 Z06, 2008 Expedition
Engine: L98, LS3, 5.4L
Transmission: 700R4, MN6, Auto
Axle/Gears: 3.23, 3.42, ?
Just curious. Do you still have the smog and emissions equipment installed on the vehicle. If not, check the ventilation hose that comes off the fuel lines on the passenger front frame rail and make sure the hose is not plugged or the charcol canister is not plugged.
Old Sep 19, 2012 | 05:17 PM
Engine: 350 L98/LS2
Already replaced the cap and that didnt do anything. Can't honestly remember if it was a vented one. Don't think it is.
And there is no smog equipment on it anymore.
Old Sep 19, 2012 | 08:59 PM
Car: 92 Camaro RS
Engine: 305 TBI
im with akanitro check that line
Old Sep 19, 2012 | 09:36 PM
Engine: 350 L98/LS2
Hoses seems to look normal. How can I check the canister?
Old Sep 19, 2012 | 10:57 PM
Davidgou's Avatar
Car: '88 Black GTA, T-tops, digital dash
Engine: 5.7 TPI w/custom chip
Axle/Gears: 9 bolt 327 posi
Question: what does disconecting the canister do? Thanks
Old Sep 20, 2012 | 10:37 AM
ChrisC's Avatar
Car: 1983 Z28/2000 ZR2
Engine: CFI to carbed 305/ 4.3
Transmission: Built 700r4/4L60e
Axle/Gears: 3:23/3:73
Does your car ever make a mooing or groaning noise after shutting it off? There is a pressure release valve that runs from the sending unit down just near the rear end on the drivers side. It will be a line dangling with a filter-looking thing on it. That is the pressure release valve. When they go bad they cause all of your symptoms, including the noise for some. If all else fails replace that. They're a dealership only part but you can just replace it with a fuel filter if need be.
Old Sep 20, 2012 | 12:10 PM
Engine: 350 L98/LS2
Nope I never hear a noise after shutting it off. Just the fuel tank popping.
I occasionally smell fuel too while driving. But not for quite awhile after i changed my fuel cap.
Gas mileage also kinda sucks
Old Sep 20, 2012 | 01:39 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
If the canister is gone, the line that ran to it from the tank is laying there on the driver's side of the radiator somewhere. Some people cap this line. I prefer to place a length of hose on it and attach it somewhere so that it doesn't pick up water or dirt. This way it acts as a vent. It's a small 1/4" steel line and runs up from the tank along with the fuel lines.
Old Sep 20, 2012 | 02:05 PM
caditech's Avatar
Car: 83 Camaro
Engine: 383
Transmission: 5 speed
Axle/Gears: 4.11
i had the same issure and drilled a tiny hole in the cap. and my problem was solved. and i dont have any gas odors. and best part, it was free lol
Old Sep 23, 2012 | 10:09 PM
hdavis2005's Avatar
Car: 1992 Camaro RS
Engine: 3.1 MPFI to 305 carb
Axle/Gears: 323
I removed the vent from my cap. No more pressure.
mustangman65_79
Apr 14, 2017 05:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
BurlyChev
Aug 16, 2015 09:08 PM
Kaweh
Aug 9, 2015 02:54 PM
