Backfiring at acceleration '84 Trans Am
Old Sep 21, 2012 | 09:43 AM
Rellling's Avatar
My Trans Am started running like crap a few weeks ago. It backfires at all accelerations and idles fairly poorly, but rarely dies. I brought it in to my school (I have a high school auto mech class) and have been attempting numerous things at my instructor's guidance. The Trans Am had a rebuilt mechanical Quadrijet carburator put in a few years ago, so the computer does nothing for the car. I've replaced spark plugs and checked compression and all that's fine. Next my instructor is telling me to check for looseness in the timing chain, but does anyone have any better ideas?
Old Sep 21, 2012 | 09:45 AM
chas 86 formula's Avatar
Car: 86 Formula 350
Axle/Gears: 331
Re: Backfiring at acceleration '84 Trans Am
Cheak the cam for flat lobe's
Old Sep 21, 2012 | 02:03 PM
dlinger's Avatar
Car: 1984 Z28 HO
Probably a dumb question, but did you check the timing? If so was it close to where it should be? If not, and setting it to where it should be make any change in how it run?
It might help for some more info (mileage on engine, changes other than carb) to help diagnose.
Old Sep 21, 2012 | 10:44 PM
383 Power's Avatar
Car: 1982 SC/1984 Z28
Engine: 305 4BBL/305 4BBL H.O.
Transmission: 700R4/700R4
Axle/Gears: 4th Gen 3.23 Posi/3.73 10 Bolt
The Carb is Mechanical, but is the Distributor still HEI? If you're running a Non-Computer Carb, you should be running a Vacuum Advance Distributor.
Old Sep 26, 2012 | 08:29 AM
Rellling's Avatar
Okay, sorry, It has 140k miles on it. And what does HEI mean? my excuse is I'm only 17 and this is my first firebird... I don't think it's flat lobes, it happened fairly suddenly on my way to school one day. I did check the timing, but it wasn't that far off. All help is appreciated!
Old Sep 26, 2012 | 05:35 PM
383 Power's Avatar
High Engergy Ignition
Andrew6.688
Dec 13, 2015 10:59 AM
Red iroc-z 305
Sep 30, 2015 05:22 PM
BewleyBizzIROC
Sep 7, 2015 08:05 PM
dyeager535
Aug 28, 2015 08:10 AM
db057
Aug 22, 2015 08:17 PM
