Like stated..I have a 92 Camaro RS Conv with a 305 TBI. I was replacing the connectors to the fuel injectors gue to the factory ones were old and cracked. I spliced and connected the wiring and before soldering I tested it and it fired right up and ran great. After soldering and wrapping I went to start it and only one injector is working. The driver side works and the pass. side doesnt. I checked it over 10 times and almost positive it is correct. The wire colors on the right injector is blue outside and red inside correct ? I checked for a brocken wire back trhrough the loom all the way back to the main harness.
Does anyone have any ideas ? Was thinking maybe ECM ?
Thanks in advance ! My first post and glad to be in good company
Could someone post a pic of the TBI wiring for the injectors please.
..::BUMP::..
