Super Victor, or Victor Jr.?
Old Sep 28, 2012 | 11:53 AM
Genopsyde's Avatar
Car: 91 RS
Engine: 355
Putting together an AFR 220 headed 406. I would like to use a Super Victor manifold, but only have a 2" cowl hood. Any ideas on if it will clear, or will I have to go with Vic Jr?
Old Sep 28, 2012 | 11:59 AM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: Super Victor, or Victor Jr.?
How much taller is the Super Vic over the Vic jr? I have a Vic jr. with a drop base 3" filter under a stock hood so a drop base with a super vic might fit under a 2".
Old Sep 28, 2012 | 12:00 PM
built91Z28's Avatar
I should also say that I'm running a Spohn tubular K-member and Moroso solid motor mounts. Not sure if this changes the height of the motor at all.
Old Sep 28, 2012 | 03:28 PM
Genopsyde's Avatar
Car: 91 RS
Engine: 355
that's what I'm hoping to find out here. I won't be running an air filter, it's a track only car.
Old Sep 28, 2012 | 03:57 PM
built91Z28's Avatar
I know edelbrocks site has all the deminsions for their manifolds. I'd check there. But if your not running a filter, I'd about guarantee you it'll fit.
Old Sep 30, 2012 | 12:24 AM
Genopsyde's Avatar
Car: 91 RS
Engine: 355
well, after a lot more reading and research, I've decided that AFR's composite SBC manifold is the way to go.
Old Jul 30, 2015 | 10:56 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
I know this is an old thread but did you actually buy the AFR intake?
Old Jul 31, 2015 | 12:19 AM
Genopsyde's Avatar
Car: 91 RS
Engine: 355
Yes i did, but the engine is still waiting to be installed so i really don't have any insight on it yet. However a friend ran one on his bracket car for a couple seasons and it was very consistent and had no problems with it, but switched to a Wilson ported Victor jr to try and go a little faster.
Old Jan 16, 2016 | 10:11 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Did you get the engine installed?
no green
Jan 9, 2016 09:22 PM
Zell1luk
Sep 29, 2015 10:36 AM
dusterbd
Sep 29, 2015 08:40 AM
Damon
Sep 26, 2015 04:29 PM
Dragonsys
Sep 25, 2015 03:51 PM
