383 one peice rear main seal balancing question?
Car: 1984 Chevy Camaro
Axle/Gears: 7.5in 10 bolt with 3.08
I'm building a 383 from a 1 peice rear main seal 350 block. I know with a 2 peice it can be internally balanced, people are telling me that a 1 peice it can only he externally balanced?
So if I go to the machine shop to balance my rotating assembly, will I still need a weighted flexplate and damper?
Re: 383 one peice rear main seal balancing question?
Sofakingdom posted this on another post.
The counterweight for their rear rod throw is still evenly distributed in the correct manner; with half of it in front of the journal, and half behind it. Unlike the 400 or similar motors, where there isn't enough volume to put the correct amount of counterweight on the inside of the journal (along the axis of the crank toward the center), and therefore too much has to go on the outside of the journal (along the axis away from the center), the 350 crank allows for the theoretically correct weight on either side of the journal, such that it is dynamically balanced. The 400 has to be done this way at BOTH ends. The reason is, that the piston is tall enough to support what the factory considered to be the minimum acceptable ring package, that the rod had to be shortened; and the bottom of the piston comes so close to the crank when it's at BDC, that there isn't enough room left for an adequate amount of counterweight. That's why, in order to "internally" balance a shrt-rod 400, you have to use metal that's MUCH denser than the material the crank is made out of.
"Internal" and "external" balance DOES NOT refer to which side of the oil seal the balance weight is on, or even whether it's part of the crankshaft proper or not.
Pre-86 SBCs had the rearward portion of the balance weight located on the crank flange, which has that funky counterweight-looking shape to it (imagine that). 86-up ones, since the seal requires that the flange be no larger than the seal, require that the rearward weight be moved to the flywheel instead of on the crankshaft, since you can't very well slide a round lip seal over that other shape.
So, the weight on the 86-up crank "looks" like it's "external", and it is in fact physically "external" to the casting; but in reality, the design is still "internally" balanced.
Which means, that all you get by asking this question, is a whole bunch of confusion. It's better to avoid those words altogether when discussing these motors, because even if you're technically correct, people will misunderstand you about 90% or more of the time. If you say those words to your machine shop or go looking for parts or whatever, you will get hosed. The best thing to call it, is "stock" balance. Which is technically "internal", but requires that part of the counterweight be "external" to the crank, i.e. on the flywheel.
So if it's a "stock" 350 with a 1pc. RMS, and a crank for a 1pc. RMS, then you'd need a "stock" weighted 1pc. RMS flexplate or flywheel, which does have the counterweight.
The only way you can be sure of your particular crankshaft balancing requirements is to contact your crank manufacturer.
I know for sure that Scat and Eagle mean different things when they say "internal" or "external" balanced.
Chances are you need a neutral balance dampner. If anyone tells you they know for sure which flexplate you need by the information you've given here, they're lying.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Some of the cheaper 383 stroker cranks ( or stroker kits ) are based on a 400 crank casting which requires both a weighted flywheel and balancer
Car: 82 Z28
Transmission: T400
http://www.summitracing.com/parts/ESP-103523750/
Notes ;
Requires a Chevy 400 harmonic balancer and the use of a stock type counter weighted flexplate or flywheel..
