Vortec swap advice
Old Oct 1, 2012 | 10:09 AM
88TransAmGuy's Avatar
Car: 88' White-Black Trans Am
Engine: Trying to find a motor
Vortec swap advice
Getting ready to start a rebuild on my sons lo5 and need some pointers from you guys. Its a 93 lo5 from a roadmaster I'll be changing the rings and bearings. I would like to put a lt1 cam in and a set of vortec heads on it. I'm not sure if I'll need new push rods with this set up? Also I have a police car chip in it and don't know if that will work with that set up? And anything else I will need to know to do this swap. Thanks
Old Oct 2, 2012 | 02:12 AM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: Vortec swap advice
You'll need a Vortec specific intake.
Old Oct 2, 2012 | 02:32 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Youll also need to verify ith as the roller cam first. The truck L05's did not but the car ones were usually supposed to get them. You should check.
Old Oct 2, 2012 | 11:10 AM
It is a roller cam so I'm not sure if the stock push rods will work with a lt1 cam and vortec heads? I know someone has to have done this swap?
xkingcodex
Feb 12, 2020 07:43 PM
Fast355
Dec 2, 2016 06:33 PM
E Rod
Aug 28, 2015 05:17 AM
Hello, Michael
Aug 20, 2015 03:19 PM
jharrison5
Aug 19, 2015 05:53 PM
