new motor is cutting out, off and on at 2,000 rpm or higher
Old Oct 2, 2012 | 08:30 PM
VMIROC-Z's Avatar
installed new motor with new stand alone ecm. when i drive up to and go past 2,000 rpm it cuts out, off and on. as soon as i let go of the throttle and let it go under 2,000 rpm it drives normal. i tried fuel filter and ignition module. maybe bad distributor, or stock fuel is going bad , im not sure. would like to get more opinions before i start going at it. anyone have any ideas/HELP ?????? thanks
Old Oct 2, 2012 | 08:59 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Re: new motor is cutting out, off and on at 2,000 rpm or higher
Fuel pressure?
Old Oct 2, 2012 | 09:02 PM
VMIROC-Z's Avatar
Originally Posted by afremont
Fuel pressure?
I'm going to try that next, I mite have to invest in an adjustable fuel pressure regulator
Posted from Thirdgen.org App for Android
Old Oct 2, 2012 | 09:08 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
I'm thinking that putting a gauge on it temporarily so you can see if it fails to hold pressure when you bring the RPMs above 2000. If it maintains pressure, then the problem is somewhere else and you can move on without spending money needlessly.
Old Oct 2, 2012 | 09:11 PM
VMIROC-Z's Avatar
True, hopefully its the old pump not holding up . because I'm currently running both stock and truck flow in-line
Old Oct 2, 2012 | 09:35 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
So your supplementing your in-tank pump with an external pump? That's definitely something to look into. I could see the in-line pump building the correct head pressure for the engine to run but the tank pump not keeping up.
Old Oct 2, 2012 | 09:52 PM
VMIROC-Z's Avatar
Exactly what I was thinking I think its just in the way and not keeping up with the demand our its just going out
Old Oct 17, 2012 | 12:54 PM
VMIROC-Z's Avatar
finally I got it running smooth, changing everything helped alot but did not fix the problem.it was the throttle position sensor lol its always the little ****
eightsixseven
Dec 16, 2024 01:50 PM
customblackbird
Aug 15, 2021 10:16 PM
355sbcTPI
Aug 19, 2015 04:38 PM
mhatfield 14
Aug 15, 2015 10:47 AM
