HELP!!!!1987 CAMARO IDLE PROBLEMS HAVE NO CLUE WATS WRONG :/
Old Oct 14, 2012 | 11:28 PM
JAYCREDIT's Avatar
I HAVE A 1987 CAMARO Z28 AND THE ENGINE LIGHT COMES ON AND OFF...WHEN THE ENGINE LIGHT IS ON THE IDLE GETS LOW WHEN THE ENGINE LIGHT IS OFF THE IDLE GETS HIGHER..THE ENGINE LIGHT USUALLY COMES OFF WEN I START IT COLD THEN SLOWLY COMES ON AFTER WARMS UP A LITTLE...I HAVE REPLACED A IDLE CONTROL VALVE,TPS,OXYGEN SENSOR THEY RELOCATED THE AREA OF IT ALSO I GOT NEW SPARK PLUGS AND FUEL PUMP IM GUESSIN IT'S MY FLOAT CAUSE IT'S KINDA OFF...I TRIED PULLING CODES BUT NO CONNECTION SMH PLZZZZ HELP!!!
Old Oct 15, 2012 | 12:01 AM
JAYCREDIT's Avatar
Re: HELP!!!!1987 CAMARO IDLE PROBLEMS HAVE NO CLUE WATS WRONG :/
it's a tpi 5.7 liter to by the way and I also replaced the mass airflow sensor
92camaroJoe
Jul 29, 2023 07:57 PM
apo_bailon15
Mar 28, 2016 05:20 AM
db057
Aug 22, 2015 08:17 PM
zeitghaist
Aug 18, 2015 07:33 AM
92camaroJoe
Aug 13, 2015 06:07 AM
