Flat Tappet and ECM
Old Oct 20, 2012 | 09:54 PM
hydrolic144's Avatar
Car: 1987 GTA Trans Am
Axle/Gears: Borg Warner 9-Bolt 3.27
Flat Tappet and ECM
Hey guys, bottom line just seeing if a flat tappet motor will run with the ECM of a 87 GTA with the 5.7? Would some tuning have to be done to the PCM, is it worth it? Just looking for some insight on it. Also does anyone know what year motors were roller blocks, I noticed a lot of trucks with them. Any specific models, years? Thanks for any help.
Old Oct 21, 2012 | 12:20 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Flat Tappet and ECM
Originally Posted by hydrolic144
just seeing if a flat tappet motor will run with the ECM of a 87 GTA with the 5.7? p.
The specs of the cam ( duration / LSA ) are better indicators of whether a cam will work with a computer rather than roller vs flat
Early (< 87) F-Bodies had flat tappet cams
96 -00 Vortec truck engine common and cheap ; chance of getting a 4 bolt main if that is important to you
Vortec heads are some of the best GM production heads ever made but require a Vortec only intake.
The block however takes any reg SBC parts , heads ,etc
Most '86+ 1 pce RMS engines are machined for rollers ( some guys on here have blocks that aren't )
but flat tappet cams were installed at the factory ( mostly truck engines)
Roller block identifiable by having flats machined on the top of the lifter bores and the 3 stands
in the valley for the lifter hold down " spider "
Old Oct 21, 2012 | 01:19 PM
Thanks for that vetteoz. I learned something. I'm already aware of how to identify the roller blocks. Didn't know vortec block parts could be interchanged like that.
So essentially, as long as the non-roller block doesn't have some radical cam, it could be used in place of my roller motor with the stock ECM and possibly not need a tuning?
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
skinny z
Oct 5, 2015 06:23 PM
hartsmike
Oct 2, 2015 07:11 AM
