fuel issue??
Old Oct 22, 2012 | 02:15 PM
maro3rdgen's Avatar
Car: 1989 camaro RS convertible
Engine: 305 TBI stock
Transmission: 700-r4
fuel issue??
ok im assuming this is a fuel issue..i could be wrong so any help is appreciated. i have an 89 camaro with 305 tbi...now the car seems to run fine but after driving for like 10 minutes it starts to sputter a little bit, mostly when i give it some gas. its done it for about two full tanks of gas so i would eliminate "bad gas" i also changed the fuel filter yesterday and same problem. tried a fuel injection cleaner and still the same result. if anybody has an idea of what this is i would appreciate it. thanks
Old Oct 24, 2012 | 10:07 PM
ChrisC's Avatar
Car: 1983 Z28/2000 ZR2
Engine: CFI to carbed 305/ 4.3
Transmission: Built 700r4/4L60e
Axle/Gears: 3:23/3:73
Re: fuel issue??
Get a fuel pressure tester that you can tape to your windshield. While driving around when the problem happens look at the gauge for low fuel pressure. This will eliminate any guess work before diagnosing a specific problem.
Glowsock
Jul 24, 2025 03:15 PM
Frozer!!!
Jan 19, 2024 04:55 PM
specialized
Jun 18, 2022 09:26 AM
Infested
May 22, 2018 11:56 PM
Bryan F
Aug 18, 2015 02:28 PM
