may have an intake leak need some info to.confirm
Old Oct 22, 2012 | 06:12 PM
91 camaro ss's Avatar
Car: 91 camaro rs?
Engine: 1985 5.7 350
Axle/Gears: 3.32
So i have a chevy 350 has a rough low end idle when i rev it above about 2k rpms it clears up an is smooth. I took some carb cleaner sprayed where the carb met the intake an it idled down like it wanted to die then sprayed where the intake meets the head then it stalled out. The only big question is is thati was always told it would make the engine idle up. i just got the rest of the issues taken care of an this is the only thing left. im eiger to get this car on the road so idñf anyone can offer any advice i would appreciate it.....also forgot to mention it has vortec heads an a gm performance mid rise intake if the engine does need intake gaskets what would be the best to use i hurd some for the vortec heads are junk gadñskets
Old Oct 22, 2012 | 07:11 PM
Re: may have an intake leak need some info to.confirm
If the fluid affects the engine IN ANY WAY, there's a leak. So yeah....
If it leaks where the carb bolts to the intake, changing the gaskets where the intake bolts to the head won't accomplish much.
Old Oct 22, 2012 | 09:14 PM
Car: 91 camaro rs?
Axle/Gears: 3.32
figures so planned on changing carb to intake bolts as well
Old Oct 23, 2012 | 05:40 AM
The leak is probably not the fault of the bolts... Change the gasket instead
Old Oct 23, 2012 | 11:56 AM
Car: 91 camaro rs?
Axle/Gears: 3.32
Lol sorry had a stupid moment ment to say gasket thanks for the advice
specialized
Jun 18, 2022 09:26 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
mike_c
Aug 27, 2015 04:32 PM
86White_T/A305
Aug 17, 2015 12:16 AM
