350 with lb9 heads
Old Oct 25, 2012 | 10:09 PM
jaydog892's Avatar
Car: 84 firebird s/e
Engine: 358 4 bolt vortec lt4 hotcam
Transmission: 89 t-5
Axle/Gears: 89 3.45 posi
350 with lb9 heads
Ok I hope someone can answer my question.I have a Jasper 350 .040 over.it's roller ready.the pistons are dished with valve relief.I have a 89 lb9 roller that I want to take heads and roller set up and put on 350.the firebird is a 5 speed w/ 3.45 posi. out of 89.I run a 600 cfm d/p Holley.hedman Shorty headers. Summit hei.manual fuel pump.I want to know if I can run cam spec of. 492 .492 lift 219 228 dur.what head gasket,valve spring pushrod,rocker arm.
Old Oct 26, 2012 | 10:50 AM
AmorgetRS's Avatar
Re: 350 with lb9 heads
Not sure why you posted this in the Pacific Northwest section, moving to general.
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
theshackle
Mar 5, 2017 06:37 PM
gta90
Sep 15, 2015 04:00 PM
NinjaNife
Aug 23, 2015 11:49 AM
