How do I know if computer in car is working....?
Car: 1984 Z28
Engine: 5.0 L (Carbed)
Transmission: 5-Speed
Axle/Gears: Lazy 2 check
Okay so I am thinking of removing the sensor thats located on the top of the thermostat in order to install a mechanical temperature gauge....I believe that the computer in the car is not working but is there a way to find out??thanks!
Car: 1984 Z28
Re: How do I know if computer in car is working....?
well when I bougbt the car it was already snogged but Im thinking that the previous owner paid to get it to pass smog...any other way to tell?
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Does the check engine light work?
Keep in mind that even if it works, it won't pass visual inspection with the sensor removed.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
can you hear the mc solenoid working ?
9192camaro
16
Feb 3, 2019 12:21 AM
