Highest RPM's my stock ignition can fire at...?
Car: 1984 Z28
Engine: 5.0 L (Carbed)
Transmission: 5-Speed
Axle/Gears: Lazy 2 check
So I launched my car all the way up to the 6000RPM area and everything seemed good until i start to hear a loud backfire.....I slow down to a complete stop and then I start to drive again and at 3000RPM's the engine starts to backfire again...I turn off the car for about 30 min and start driving again and its back to normal...
My question is that what would be the top RPM's that my stock ignition can handle??and what could've caused the backfiring at those RPM's...?thanks!
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
Re: Highest RPM's my stock ignition can fire at...?
6000 should be no problem if you have an HEI in good working condition. I run mine to 7000 and don't have an issue. More than that and you should consider aftermarket though, imo.
If you don't run HEI I don't know your answer however.
eightsixseven
Dec 16, 2024 01:50 PM
9192camaro
16
Feb 3, 2019 12:21 AM
92camaroJoe
Aug 13, 2015 06:07 AM
