lo3 misfire
Old Nov 2, 2012 | 02:51 PM
AJHECK95's Avatar
Car: 1989 formula
Engine: stock lo3 305
Axle/Gears: dont know
lo3 misfire
my 89 lo3 has a missfire and i cant figure it out. i have good compression and my cap, rotor, coil, plug wires, and plugs are new also has new fuel pump. when it idles it aint too bad but when you put a load on it like power braking it misse violantly. is there other sensors that can be causing this? im not too good with fuel injection so i could really use some input. thank you
Old Nov 2, 2012 | 05:58 PM
ex-x-fire's Avatar
Re: lo3 misfire
Look for a rusty pick up coil in the distributor.
Old Nov 8, 2012 | 01:47 PM
AJHECK95's Avatar
Car: 1989 formula
Re: lo3 misfire
it looks a little corroded, but if that was bad would it still be able to run.
Old Nov 8, 2012 | 02:10 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
Re: lo3 misfire
Could also be timing. Not sure on that car how the timing is controlled, probably via computer, but it's worth checking your initial and see if you accidentally tweaked the distributor.
db057
Jan 10, 2020 08:55 PM
NZKnight
Oct 15, 2015 02:47 PM
anesthes
Sep 21, 2015 10:24 AM
64Chief
Sep 12, 2015 08:05 AM
Stroopwafel
Sep 11, 2015 06:38 AM
