broke down help please
Old Nov 2, 2012 | 10:48 PM
Ridngchoppers's Avatar
Car: 86 chevy 28 camaro
Engine: 305 tpi
My car wont start in the cold but when it warms up it will start fine. I parked it for the day and it wont start now since it got cold. I wont use either last time it almost burnt car wont down.
Old Nov 2, 2012 | 10:49 PM
Engine: 305 tpi
Re: broke down help please
Its a 305 smallblock tpi
Old Nov 2, 2012 | 11:19 PM
GTAman's Avatar
Car: 1988 Trans am GTA
Engine: corvette 350 swap
Transmission: t-5 swap
Axle/Gears: 3.27:1 borg warner 9-bolt w/ PBRs
what almost burnt the car? please give more specifics.
Old Nov 3, 2012 | 08:30 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Sounds like the cold start injector is not working. It is powered by the 3 amp CRANK fuse, so check that first. The switch for it is mounted at the front of the engine, up top.
The switch is thermally activated, on a cold engine it is closed and the cold start injector sprays fuel. When the engine reaches a certain temperature the switch opens and the injector turns off.
RBob.
Old Nov 3, 2012 | 08:56 AM
Dakota W.'s Avatar
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
I think he was trying to say ether, but I'm not sure.
Old Nov 3, 2012 | 03:14 PM
Engine: 305 tpi
RBob.
k thanks can u give me a more specific place of the fuse?
Pac J
May 17, 2020 10:44 AM
Bubbajones_ya
Oct 25, 2015 08:01 PM
wanext
Oct 6, 2015 12:18 AM
bjpotter
Oct 4, 2015 07:48 PM
sjorgens
Oct 1, 2015 07:54 PM
