1984 Z28 Camaro won't start
Old Nov 4, 2012 | 01:01 PM
Hjnztw's Avatar
While driving my 1984 Z28 Camaro, the engine shut off as I made a left hand turn. It is a manual transmission. I tried starting it up but it won't turn over, doesn't make a clicking sound, radio, turn signals and fan won't work, headlights and interior lights work. Any help would be greatly appreciated.
Old Nov 4, 2012 | 01:18 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
Re: 1984 Z28 Camaro won't start
Sounds like either a fuse blew (unlikely), or part of the engine wiring harness came unhooked when you made the turn. Also possible a ground wire came loose. I don't know about thirdgens, however on older GM vehicles there's a wiring harness plug that goes through the firewall, and it is possible for it to come loose if the bolt is missing.
Old Nov 4, 2012 | 02:08 PM
Hjnztw's Avatar
Thanks! At least now, I have a place to start.
Old Nov 4, 2012 | 04:10 PM
mpb74's Avatar
Car: 1986 Iroc-Z
Engine: 355 Phase 2 Bowtie heads
Axle/Gears: 342
You may have lost power to your coil.
Old Nov 4, 2012 | 04:30 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Not going to affect the radio or starter is it.
Old Nov 4, 2012 | 04:46 PM
BumpaD82's Avatar
Car: 1982 Z28 & 1967 RS & 2002 Z28
Engine: 388 ci SB / 454 ci BB / LS1
Transmission: 4 speed / TH350 / T56
Axle/Gears: '91 "1LE" rear, posi w/ 3.23's
I believe the hot wire for the battery to the starter has a fusible link ... Check continuity on ALL the wiring off the battery / alternator / starter ...
Old Nov 4, 2012 | 07:24 PM
Hjnztw's Avatar
Thanks a lot! I will have to check the wiring for fusible links...I am just not sure what they look like in the Camaro. I will have to do some farther research. But that would make sense as to why some electrical components work and others don't.
84z96L31vortec
Aug 20, 2017 12:16 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
justin57
Aug 20, 2015 07:05 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
Exxon Limited
Aug 9, 2015 08:13 PM
