Squeaky noise when clutch is let out....??
Old Nov 6, 2012 | 07:31 PM
calgutie's Avatar
Car: 1984 Z28
Engine: 5.0 L (Carbed)
Transmission: 5-Speed
Axle/Gears: Lazy 2 check
So on my 84 z28 when ever Im driving and im at a complete stop and the clutch is fully let out I always hear this squeaky noise but as soon as I lightly tap on the clutch it goes away...anyone know how to fix this or why it makes that noise??thanks!
Old Nov 7, 2012 | 12:25 AM
1986Z28OWNER's Avatar
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
Re: Squeaky noise when clutch is let out....??
Throwout bearing. Transmission needs to be removed.
Old Nov 7, 2012 | 07:53 PM
jtsk's Avatar
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
yep, sounds like a throwout bearing. It will need to be replaced and that means dropping the tranny. Not too terribly tough to do if you got the tools. You can also take it to a tranny shop and have it changed.
Old Nov 7, 2012 | 08:48 PM
calgutie's Avatar
Car: 1984 Z28
Im thinking of replacing my clutch around January you think ill be ok?and when i try to go into reverse it tends to grind...
Old Nov 8, 2012 | 05:33 AM
jtsk's Avatar
Hard to say. If you drive every day in heavy traffic it may not make it. I had a 71 Camaro that didn't make it 2 weeks after the noise started. I would change it ASAP though.
Old Nov 8, 2012 | 08:32 AM
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
mine has been like that for 4 years, but yes trans needs to come out and its more than likely your TOB
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
sjorgens
Oct 1, 2015 07:54 PM
mfp189
Sep 27, 2015 09:25 AM
