starting issues
Old Nov 9, 2012 | 01:38 PM
Zach/90\irocZ's Avatar
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
starting issues
my trans went out and went to swap a t56 in before i would start it here and there then it sat for awhile i try to charge battery it crank over then it just stop and when i turn key nothing happens well fast forward t56 is in all wired up i tried to jump and charge battery to start same thing happen i turn key and nothing happens no clicking no starter noise no nothing i replace battery due to taking it to autozone testing saying battery bad still nothing happens i turn key on to try to start and nothing happens i dont even hear a click from "maybe starter relay bad" i swear i use to hear a little click in dash when starting i double check lt1 starter wiring it was correct im going to double check again and try to replace starter relay if autozone has it also i have the starter saftey switch wired together its the top two wires in the auto shifter wiring the two big wires just so i can start engine since its been sitting
do i have bad starter relay?
i will double check starter wiring also.... after work any info to help thanks
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Bryan F
Aug 18, 2015 02:28 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
86Base
Aug 8, 2015 01:34 PM
