What a good oil Viscosity for Winter/Colder Temps....
Old Nov 10, 2012 | 08:31 PM
calgutie's Avatar
Car: 1984 Z28
Engine: 5.0 L (Carbed)
Transmission: 5-Speed
Axle/Gears: Lazy 2 check
So I live in SoCal and the weather down here isn't as bad as other states but I was just wondering if changing my oil viscosity to something other than what I have always been using will help my car out for those cold morning starts...?thanks Im using Valvolines 5W-30
Old Nov 10, 2012 | 08:36 PM
Damon's Avatar
Re: What a good oil Viscosity for Winter/Colder Temps....
The first number (5W) indicates the cold viscosity of the oil. It behaves like 5W oil when cold, but 30W when hot.
That is NOT to say that the oil is thinner when cold than when it's hot. It's just not as thick as straight 30W would be at the same cold temp.
Long story short, keep using what you're using.
Old Nov 10, 2012 | 08:38 PM
calgutie's Avatar
Car: 1984 Z28
alright...thanks for the info..
Old Nov 10, 2012 | 08:40 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Just keep using what you are. Once the motor heats up, it doesn't matter what the temp outside is.
Old Nov 10, 2012 | 08:43 PM
calgutie's Avatar
Car: 1984 Z28
thats true....thanks!
Old Nov 10, 2012 | 08:44 PM
Agreed; that's an all-around workhorse oil grade. Keep using it.
Old Nov 10, 2012 | 08:49 PM
calgutie's Avatar
Car: 1984 Z28
All you guys have a point ill just keep my 5w-30 then thanks you guys..
db057
Aug 22, 2015 08:17 PM
Navy8125
Aug 21, 2015 09:32 AM
355sbcTPI
Aug 19, 2015 04:38 PM
ChevyZ71
Aug 13, 2015 07:30 AM
