trying to calculate my comp ratio...
Old Nov 11, 2012 | 04:27 PM
Regal105's Avatar
Car: 83 c10, 2015 silverado
Engine: 454, 5.3
Transmission: Turbo 35o, 6l80
Axle/Gears: 3.42, 3:23
looking for a little help i built a 406 last spring haven't started it yet, just don't have the time... anyway i have what i estimate to be 62 cc heads, 4.155 bore "duh" used a Mr. Gasket rebuild kit so i don't know how thick the head gasket is or the piston to deck height but the pistons have a 22cc dish any help would be greatly appreciated. the pistons are speed pro cast pistons for the stock rods! thanks!
Old Nov 11, 2012 | 04:41 PM
Re: trying to calculate my comp ratio...
Well with all that extreme precision, it hardly seems worthwhile to "calculate" anything, since no matter how many decimal places a "calculation" is carried out to, it's still only as "good" as the input data; but FWIW...
With 62cc heads, 22cc dish, .050" of deck clearance (stock is .025", -.000" to +.015" or so, so I'm allowing .005" just to be sort of average-ish, plus the extra .020" of "rebuilder" clearance built into the pistons), .039" gasket:
Comes out to right at 9:1.
Old Nov 12, 2012 | 11:47 AM
Regal105's Avatar
Engine: 454, 5.3
yes the heads started life as 64's but have been milled down slightly, but all in all if it stays in the 9's ill be happy, if not i guess ill probably switch to a vortec head
Pac J
May 17, 2020 10:44 AM
no green
Jan 9, 2016 09:22 PM
