transam gta distributer help
Old Nov 22, 2012 | 11:42 AM
gta power's Avatar
hi need help on my trans am gta 5.7 tpi due to not sparking have ordered new cap rotor coil ignition module and pick up coil how do you take the distributor out to fit the pick up coil
Old Nov 22, 2012 | 11:53 AM
Re: transam gta distributer help
Remove the bolt; lift.
You'll have to remove the gear so you can pull the shaft so you can change the pickup coil. Requires about a 3/16" punch or thereabouts, can't recall exactly but it's near that size. Make sure you note which way the gear goes on the shaft (there's an alignment dot) because there's an odd # of teeth, meaning things will line up weird if you put the gear back on backwards.
Old Nov 22, 2012 | 12:13 PM
gta power's Avatar
many thanks mate parts should be here soon will let you know if i need any help thanks again for the reply
NZKnight
Oct 15, 2015 02:47 PM
bigjay89gta
Oct 15, 2015 08:04 AM
drptop70ss
Oct 4, 2015 09:44 PM
Dragonsys
Sep 25, 2015 03:51 PM
