305 feels like a dog
Old Dec 4, 2012 | 11:19 PM
89 iroc convert's Avatar
Car: 1989 iroc convertible
Engine: 305 tpi
Transmission: 700 r4
I got a 89 305 lb9 in a iroc convertible got stur tower braces ,subframe connectors on order to stiffen body up but im not happy with th engine .
can my 305 be built toget more hp or would i be wasting money ? several motor head friends tell me to dump the motor and get a crate motor any advice ? its an all orginal car in great shape 140 k on motor adult owned from new was my parents car .theyare now retired ive had it 6 weeks .
dont want to gut out a nice car Help please
THANKS IN ADVANCE
Old Dec 4, 2012 | 11:58 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
Re: 305 feels like a dog
It can be made to have power but for the same money invested a 350 can make the same power with more torque at a lower RPM (usually 500-700ish lower).
I'd personally not waste any money on parts that wouldn't be interchangeable between a 305 and 350 (headers, exhaust, intake, roller rockers). If you still aren't happy buy a 350 and swap those parts on (I believe the biggest difference in the TPI 305 and 350 is the injectors). If you want even more power do a small cam. Or go crazy if ya have the coin to spend and get an HSR setup, spin 6,500 RPM get aftermarket heads and make 450 horses.
Old Dec 5, 2012 | 07:45 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
I agree totally with the above statement. Only items that can be swapped over to a 350.Befor you start digging inside the engine and if its going to stay off the track and wont see sticky tires and it stays a automatic I don't see any reason to not build or most likely swap in a better rear gear ratio. with a posi. traction of some sort.(I built mine with a 3.42 ratio. and Eaton posi. with support cover).Thats the biggest bang for the buck and will show immediate results.
A nice shift kit will tighten things up with your shifts.(I simply went with a Corvette servo. and called it a day).
There are all the common bolt ons like a better flowing full exhaust.(Headers ,and then all the way out)
Here's a easy one, bump your timing a bit. I set my TBI at 4* advanced and it has made a nice difference in throttle response off the line. I did most of the above and can say that the cars allot more fun to drive.
Old Dec 6, 2012 | 10:16 AM
Engine: 305 tpi
thanks for the input ill try the suggested mod and see what i think
Old Dec 6, 2012 | 10:29 AM
Camaro305SB's Avatar
Car: 87 Camaro
Engine: 305 LG4 (H)
Heads, cam, gears, and converter (if auto) will more than likely make you a happy camper.
NORTz89
May 20, 2020 03:51 PM
gta90
Sep 15, 2015 04:00 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
flash2042
Exterior Parts Wanted
Aug 7, 2015 05:58 PM
