aluminum heads stock manifolds
Car: 1988 gta
Engine: 383
Axle/Gears: 9 bolt 3:23
Machinist buddy of mine pointed out that the after market heads don't have the extra bolt hole that the stock exhaust manifolds need on a 1988 GTA. I seem to be running out of options for a decent head
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: aluminum heads stock manifolds
Why spend the money on good heads and then choke it with stock manifolds? You can get emissions legal shorty headers that flow good and keep good ground clearance.
Car: 1991 Camaro RS
Axle/Gears: 7.6" 3.73 yukon locker
well maybe because the reason I am doing the same thing. To keep it looking stock but bump the engine a little.
I am with you on the choking part... and headers could add 30 HP all alone. But... looks have something to do with it to.
I would like to see how this one goes and if someone does make a 7 hole head.
Car: 1988 gta
Engine: 383
After researching what's available on ebay, there seems to be quite a few aluminum heads with the 7th hole, but with questionable quality. What I did notice is that the angled plug heads will interfere with the #5 cyl. with the stock manifolds.
http://www.goodson.com/technical_sup...ing/CHC-10.pdf
You could give this a try and let us know how it works.
transaero
Aug 31, 2015 01:14 AM
