How Well Does Your Rear Defroster Work?
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
Kind of a random question here, but I was curious to know how well everyone's rear defroster works.
I never really thought anything about it before figuring it to be just the age of the car/design they used back in the 80s, but the performance of my rear defroster seems really lacking. Usually takes about 10 minutes to thaw out the back window.
Is this typical of thirdgens, or is something up?
Engine: 4++,350 & 305 CIs
Re: How Well Does Your Rear Defroster Work?
Thats normal. Its a big window.
My 08 G5 takes atleast that long to defrost a smaller rear window and about 10miles or more to really start putting heat out.
Car: 1985 Z28
I really only try to use the rear defroster while the car is moving or I have my foot on the gas a little since I have an underdrive pulley setup and the large load at idle is really hard on the alt. I'm gonna have to get into the viper programming and disable the feature that turns the rear defroster on with the remote start when the ambient temp is 55F or lower (Had the stock pulley setup at the time I installed the viper).
Car: 87 Camaro
Engine: 305 LG4 (H)
My defroster draws a ton of amperage and makes the belt squeal like a BITCH - and it doesnt even work that well. I'm confident theres a problem though since mine was hit pretty hard in both rear quarter panels. I just scrape it off now lol.
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
If you repair the lines going to the defroster, that should help ease the power consumption. Mine are corroded badly and need to be replaced but I don't know how to get that side panel off to get to them.
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
There is a similar rear defrost thread with diagrams, service manual schematics,
pics , comments here:
https://www.thirdgen.org/forums/inte...ster-time.html
Mine works fairly well actually.
I have however replaced the wires from behind the panel, coming out around the end of the "strut"; made AHELLUVALOT of difference. They were all corroded and green and obviously not carrying electricity very well any more.
Car: 1984 Trans Am
How did you get those panels off? I can get them off from the tail lamp area, but moving forward to the middle of the car they seem to get stuck om something. Is there a hook, a hidden latch, or bolt I need to take off to get them loose? I obviously don't want to break the panel.
AkDrifted
Aug 17, 2015 07:45 PM
