Very Annoying Humming Sound
Old Dec 27, 2012 | 11:20 PM
tylerf's Avatar
88 transam am gta 5.0 auto
so about a month ago my car would started to make a humming noise when i would give it alittle gas ( 1,100 rpm) then stop,now it has changed. when the car is atleast going 1mph it will make a humming noise that sounds like it is coming from the front, but very hard to tell. if i am giving it gas the humming goes away, if i am just coasting without gas it hums, sitting at idle there is no humming, ive had people sit on the hood in my parking lot to see if they could hear where it is coming from but there clueless, my father swears when hes sitting in the pass seat he can feel it on his feet vibrating but i cant. any ideas what could cause it to hum when the car is moving without gas?
Old Dec 28, 2012 | 09:21 AM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: Very Annoying Humming Sound
How's the motor mounts? Is the exhaust system touching the underbody anywhere?
Old Dec 28, 2012 | 10:05 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Might be your fuel pump,they hum naturally.
Old Dec 29, 2012 | 07:09 PM
FtrSpeedy's Avatar
Car: 14 scion tc/91 camaro rs
Engine: 2.5/ 360 pooch
Transmission: 6spd man/th350
Axle/Gears: na/2.73
How are the front brakes and wheel bearings?
Old Dec 29, 2012 | 08:56 PM
unseenT/A's Avatar
Car: 1987 Trans Am
Engine: Patriot Performance 383 500hp
Axle/Gears: Dana 44 4.09's
You don't have any poly mounts on the car do you? they transmit MUCH more vibration than a rubber mount
Lbibb
May 5, 2016 12:00 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
wanext
Oct 6, 2015 12:18 AM
Fanatic1074
Oct 2, 2015 03:47 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
