Intake manifold block off plate?
Old Dec 28, 2012 | 03:20 AM
cactusman92's Avatar
Car: 1991 Chevrolet Camaro Z/28 (Project
Engine: 5.0L 305
Transmission: 700R4 W/ B&M shift kit
I recently purchased an intake manifold gasket set it came with block off plates for the middle ports. the car is a thottle body injected 305 backed by a 700r4 with a b&m shift kit. My question is would it be beneficial to install the block off plates keeping in mind its a daily driver or would it be better to just keep the ports open? explainations would be great appriciated THANKS in advance.
Old Dec 28, 2012 | 03:52 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Intake manifold block off plate?
Middle port on heads are the exhaust gas supply to the EGR valve.
If EGR is not operating then you will throw a code
Old Dec 28, 2012 | 09:21 PM
Engine: 5.0L 305
thank you for your input thats pretty much all i needed to know
Jake_92RS
Jan 28, 2020 10:37 PM
midge54
Jan 29, 2017 07:00 PM
anesthes
42
Oct 24, 2015 07:30 PM
theurge
Aug 21, 2015 12:46 PM
1985chevydude
Aug 20, 2015 12:29 AM
