HVAC
Old Dec 30, 2012 | 11:02 AM
marcus88's Avatar
Car: 87 GTA
Transmission: Automatics
HVAC
Any pics or info on vacuum line for HVAc system? 87 GTA digital dash & push button heat/ac controller...air is only blowing from the defroster...
Old Jan 8, 2013 | 08:44 AM
Rickey_85TA's Avatar
Car: 1985 Pontiac Trans Am
Engine: 305 (5.0L) TPI
Axle/Gears: 9 Bolt Borg Warner Posi-traction
Re: HVAC
Hi marcus88
I'm chasing the same problem and so far I have found that the vacuum lines run from the passenger side of the intake plenum, next to the distributor. One line runs around the back side of the distributor (next to the firewall) into a "T" connector. From there, one line goes through the firewall somewhere behind the engine, the other goes all the way to the driver side strut tower. It then connects to another "T" connector. The line then goes to the cruse control device and a "vacuum ball" under the battery, behind the fog light.
I find that the rubber hoses are dry rotting and they collapse or break when vacuum pressure is applied. Best thing to do is buy several feet of vacuum tubing from a local auto parts store and replace it all. The sizes are written on the side of the old tubing. You will need 2 different sizes of rubber tubing (i don't remember the exact sizes).
Also, there is hard plastic tubing that runs to the EGR valve and throttle body. These usually break if you move them around too much, so be careful.
Old Jan 8, 2013 | 05:22 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: HVAC
These diagrams will show which actuators control which doors.
File Type: pdf
Old Jan 8, 2013 | 05:25 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: HVAC
And this
File Type: pdf
Old Jan 8, 2013 | 05:33 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: HVAC
Sorry, try this.
Casey Meyers
Mar 2, 2016 10:46 AM
777Shock777
Oct 29, 2015 04:30 PM
timonator
Sep 30, 2015 12:52 PM
Chevykid810
Sep 28, 2015 12:57 PM
Eric-86sc
Sep 28, 2015 11:37 AM
