350 build help.... may be using L98 heads?
Old Jan 5, 2013 | 02:54 PM
VandykeT/A's Avatar
I've got a 3970010 block and a set of stock 91 L98 heads. I'd like to make 350 flywheel horsepower with this engine (flat tappet engine). What would be a good cam/intake set up with the heads I have to make that power, if possible. Its going in a 80 Trans Am with a th350, 2200 stall, and a 308 gear.
Old Jan 5, 2013 | 02:57 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: 350 build help.... may be using L98 heads?
Don't think you will even make 300hp with those heads.
Old Jan 5, 2013 | 02:58 PM
ninetyone's Avatar
Axle/Gears: 3:42
Go get some vortec 350 truck heads in the junkyard instead.
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
CRFred
Feb 7, 2016 11:39 PM
NinjaNife
Aug 23, 2015 11:49 AM
NWAsonoma
Aug 18, 2015 05:45 PM
