starting problem and tumbler ???
Old Jan 16, 2013 | 08:01 PM
mb2hurley's Avatar
Car: 91 camaro rs
Engine: v6 :/
Transmission: auto
my starter went out on my 91 v6 rs. i replaced it and now when i turn the key to start it clicks then nothing, and then i try it again it starts just fine, everytime its like that. why?
second question is for a 88 iroc 5.0 my ignition key tumbler i assume is bad, my key is stuck in it, i cant turn to start or take the key out anymore. ive never replaced a tumbler before, just lookin for a quick how to. i think the steering wheel comes off to take all that plastic out or is there a easier way?
Old Jan 22, 2013 | 04:35 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
No Go Yo
If it’s under warrantee replace it.
If you want to do it the fast way, replace it.
If not:
Most likely there is a loose or dirty connection from the solenoid to the starter.
Once you clean or verify that connection is clean but the problem persists, you can connect a wire to the ‘M’ connection.
Make the wire long enuff to bring into the cockpit.
Connect a bulb to the wire, and ground the other terminal of the bulb.
Now, when you try to start, but it won’t crank, observe if the bulb is lit.
If no, the solenoid is bad.
If yes, the starter is bad.
Iggy Switch:
Hopefully someone will have the time to chime in with the disassembly and reassembly of the Ig switch problem.
Happy Racing!
I Don’t Mind Wreckin’ On The Track, No Paperwork To Fill Out
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
