89 Formula 305 TPI Issues
Old Jan 17, 2013 | 11:38 AM
89Formula Dan's Avatar
Hello guys,
I have a 89 formula 305 5 speed that runs great when cold but sounds and feels like it is missing when engine is warm. During driving when fully warmed up, I can push the gas to the floor and the car just stutters. When the engine is cold it runs good with a lot of power. I Checked the timing and it was at 12 with the ECM jumped. I set the timing to "6" per the manual and the car runs even worse. I have checked all vacuum lines. Does anyone have any ideas on the fix for this? Here is a List of parts that I have replaced.
TPS Sensor
Oxygen Sensor
High and Low Engine coolant Sensor
Knock sensor
Fan temp switch
Oil pressure sensor
Full distributer with cap and rotor
Plug wires
Spark plugs
Coil
2 High flow Catalytic Converters
Air filter
Battery
Thank you,
Dan
Old Jan 17, 2013 | 02:42 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: 89 Formula 305 TPI Issues
OHM your injectors when car is warm. If they are stock, those are prone to shorting out. Do a search here for the "how to".
Old Jan 17, 2013 | 04:04 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Originally Posted by 89Formula Dan
Hello guys,
TPS Sensor
Oxygen Sensor
Knock sensor
Fan temp switch
Oil pressure sensor
Plug wires
Spark plugs
Coil
Air filter
Battery
Thank you,
Dan
test your fuel injectors. Ohm test. Sounds like you may have a bad one.
Old Jan 17, 2013 | 10:50 PM
southbay08's Avatar
If you get any reading that are 12ohm or less, you will need to replace the injectors
www.southbayfuelinjectors.com
516-442-4707
Old Jan 17, 2013 | 11:05 PM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
Did you unplug the est bypass connector when you timed the engine? Will have to retime it if you didnt.
gta90
Sep 15, 2015 04:00 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
