Please Identify This Piece
Car: 1988 Pontiac GTA
Engine: L98 5.7L
If anyone can identify this part, it would be much appreciated. Piece broke off of it so i can no longer attach a hose. Thanks.
Re: Please Identify This Piece
check valve
GM# 10135692, 15733271 or ACDelco 15-5421
http://www.ebay.com/itm/83-92-GM-Cam...sories&vxp=mtr
similar but not original
http://www.amazon.com/ACDelco-140566.../dp/B000C9F658
original
http://www.ebay.com/ctg/ACDelco-1405...alve-/99167065
original
Engine: L98 5.7L
Thanks a lot. Not the most important thing in the engine bay, but like to keep things in check and keep the car running right.
Yup, check valve...
YOu can get em in the Help! section at AZ and such. All it does, is let vacuum go through one way, but not back the other; that way things that work off of vacuum, like the AIR controls, hold their settings if the vacuum goes real low, such as if the driver floors the gas.
Engine: L98 5.7L
Good to know. Thanks for the information. Couldn't find it in the Chilton manual.
